Batch Processing
Starting from version 2.4, iPi Mocap Studio supports Batch Processing.
- Many steps are required to obtain final result. For instance, the following sequence of processing steps is quite common to obtain high quality results:
- Track Forward starting from the first frame of Region-of-Interest.
- Refine Backward starting from the last frame of Region-of-Interest.
- Jitter Removal with 2 as smoothing value for all body parts.
- One more Refine Backward starting from the last frame of Region-of-Interest.
- One more Jitter Removal with 1 as smoothing value for all body parts.
- Processing of many takes and/or many video files
- Experimenting with different processing and post-processing settings for one and the same source video. For example:
- Tracking with various options for shoulders, spine, head and foot.
- Jitter Removal with various values of smoothing.
- Trying of various actor parameters like actor's height and body mass index.
Note. Batch Processing is available only in STANDARD edition. In other editions you can try this functionality, but the results of Batch Processing will be saved in restricted trial format which prohibits export of animation.
Vocabulary
- Processing Pass (or simply Pass)
- Processing operation on Region-of-Interest for Mocap project. Currently the following passes are available:
- Calibration (for color cameras and for depth sensors)
- Track Forward/Backward
- Refine Forward/Backward
- Apply Jitter Removal
- Apply Motion Data for Gyro Sensor
- Batch Step (or simply Step)
- Element of batch. Consists of the following information:
- Input Mocap project file name
- Output Mocap project file name (by default is the same as input)
- Processing Pass (see above)
- Values of Parameters of the Pass
- Current Timeline Position (or simply Frame)
- Region-of-Interest
- Batch
- Sequence of Batch Steps. Can be saved on disk, loaded from disk, executed.
Batch Creation
- Switch to Batch tab.
- If required, clear current batch by clicking New button on the top of the tab.
- Click Record to Batch button (or press Ctrl+Shift+B on keyboard).
- Red ball should appear in the Batch tab header.
- Open existing iPiMocap project or create new one and save it on disk.
Note. Batch processing deals with project files on disk. Thus before adding new steps for project to batch, the project should be saved on disk.
- Prepare all required aspects for interested processing pass like Region-of-Interest, current position on time-line (current frame) and other parameters specific for the processing pass just like you're going to perform it right now.
- Press button which corresponds to the interested pass.
Note. During "Recording to Batch" such buttons are highlighted with pink background color.
- You will be asked what to do: Add to Batch or Perform Now. Choose the first one if your indeed want to add the pass to the current batch.
- If required, you can change output file name for project and/or choose input project file name from available alternatives. To do it click buttons on the right of input and output fields respectively.
- Also you can check values of specific for the pass parameters by clicking "i" button on the right of pass field.
- Repeat steps starting from 5 or 6 for all required processing passes, Regions-of-Interest and projects.
- To stop "Recording to Batch" click Stop Batch Recording button on the Batch tab or press Ctrl+Shift+B on keyboard.
- Optionally, you can save resulted batch to file on disk by clicking Save... button on the top of the Batch tab.
Batch Editing
- Delete step.
- Move step up/down in the batch sequence.
- Change destination file name. It's required if you want to save results of different processing stages to different files or if you're experimenting with different settings thus results for alternative settings should be in separate project files.
- Choose source project from the list. This list consists of all unique output file names of previous steps in the batch which have the same source project as their input. It allows to set alternative processing chains for one and the same source project.
Note. Undo/redo functionality is available for all manipulations with batch.
Execution of Batch Processing
- Batch Recording is stopped.
- Current batch is not empty and contains at least one uncompleted step.
Note. If required, you can break batch execution by clicking Stop button.
After batch execution, for all touched steps additional information will appear:
- status
- Status of the step after batch execution. Can be one of the following:
- PROCESSED — processing pass completed successfully.
- ERROR — processing pass can't be performed due to error. To get additional information about error you can click "i" button on the right of status field.
- CANCELED — batch execution was stopped by user while this step was in processing.
- date
- Date of step execution.
- time
- Time period of step execution.
How it Works
- Loading project from file specified as "input".
- Adjusting of Region-of-Interest to the interval specified in the batch step.
- Moving timeline position to the frame specified in the batch step.
- Changing parameters of the processing pass to values saved in batch step.
- Saving project to file specified as "output".
- Starting appropriate processing pass.
- As soon as pass completes, saving project to file specified as "output".
- Switching to the next batch step if exists.
Some consequences:
- If you produce and save some changes in the Mocap project after batch creation but before batch execution and this project is used in the batch, then these changes will affect batch execution in spite of the fact that batch was created before.
- Actor(s) properties are not saved in parameters of tracking passes. Thus, to experiment with different actor parameters like height, you need to save all interesting combinations to different project files and add processing steps to the batch for each of these files.
