Revision as of 21:45, 6 August 2013 by Andrew (Talk | contribs)
Starting from version 2.4, iPi Mocap Studio supports multiple person tracking with the following limitations:
  • Currently only two actors tracking is available in the public release.
    • Tracking of more than two actors requires more RnD and currently not feasible due to mutual occlusion of actors.
  • At least 5 Sony PlayStation Eye cameras are required to track multiple actors.
  • It's recommended to use 68 cameras to track multiple actors.
  • For simple actions when actors are rarely close to each other you can use 45 Sony PlayStation Eye cameras or even two depth sensors (MS Kinect / ASUS Xtion / PrimeSense Carmine).
  • For single depth sensor and for 3 web cameras multiple person tracking is not enabled.
  • Multiple person tracking is available only in STANDARD edition. In other editions you can try this functionality but in this case all results will be saved in restricted trial format which prohibits export of result animation.
Actors Clothing
For color cameras:
  • All standard recommendations.
  • Plus it's highly recommended to use different colors for clothing of different actors. It allows to minimize the probability of miss-tracking in case of close actors positions.
For depth sensors:
Cameras Configuration
The main idea is to minimize self and mutual occlusions of actors. In general, 58 cameras should be placed in full-circle with at least two cameras at 2.5+ meters height. If you're going to use less cameras then all actions should be planned in such way which minimize mutual actors occlusion. For example, screenshot below demonstrates how to shoot two actors handshake with the aid of just two depth sensors:
Scene Configuration Example
T-pose
It's convenient but not strongly required when both actors stay in T-pose at one and the same time as far from each other as possible (both actors should be fully visible in all cameras).
T-poses of Actors
Processing
  • During project creation you will be asked about actors count and then about each actor parameters:
How many actors?
First actor parameters
Second actor parameters
  • At toolbar you will see buttons for switching between actors. Also you can switch by clicking on actor model in the 3D view port. Skin of "inactive" actor is grayed. Content of Actor tab is displayed for active actor.
Active actor on UI
  • For each actor:
    2. Adjust actor parameters if needed.
    3. Click Analyze Actor Appearance button.
    4. Correct actor's colors with the aid of Eye dropper if needed.
      Note. Unlike all other content of Tracking tab this button touches only active actor and doesn't affect on the second one.
  • Adjust Region-of-Interest, choose settings for tracking on Tracking tab and execute it with the aid of appropriate button.
    Note. All options and buttons on the Tracking tab except Refit Pose button concern all actors all together.
Tracking Tab Controls
Motion Controllers
  • left hand of the first actor
  • right hand of the first actor
  • head hand of the first actor
  • left hand of the second actor
  • right hand of the second actor
  • head hand of the second actor
Or any subset of these items.
Animation Export
Using Import target character on Export tab you can import target character for active actor. If you want to import target character for the second actor, just make it active using buttons on toolbar and repeat importing. Target characters can be one and the same or different.
Export
Demo
