Revision as of 12:32, 7 August 2013 by Pavel (Talk | contribs)
Starting from version 2.4, iPi Mocap Studio supports multi-person tracking with the following limitations:
  • Currently only two actors tracking is available in the public release.
    • Tracking of more than two actors requires more RnD and currently not feasible due to mutual occlusion of actors.
  • At least 5 Sony PlayStation Eye cameras are required to track multiple actors.
  • It's recommended to use 6 — 8 cameras to track multiple actors.
  • For simple actions when actors are rarely close to each other you can use 4 — 5 Sony PlayStation Eye cameras or even two depth sensors (MS Kinect / ASUS Xtion / PrimeSense Carmine).
  • For single depth sensor and for 3 web cameras multi-person tracking is not enabled.
  • Multi-person tracking is available only in STANDARD edition. In other editions you can try this functionality but in this case all results will be saved in restricted trial format which prohibits export of result animation.
Actors Clothing
For color cameras:
For depth sensors:
Cameras Configuration
The main requirement is to minimize self- and mutual occlusions of actors. In general, 5 — 8 cameras should be placed in full-circle with at least two cameras at 2.5+ meters height. If you're going to use less cameras then all actions should be planned in such a way which minimize mutual actors occlusion. For example, screenshot below demonstrates how to capture two actors handshake with just two depth sensors:
Scene Configuration Example
T-pose
T-poses of Actors
Processing
How many actors?
First actor parameters
Second actor parameters
Active actor on UI
  • For each actor:
Tracking Tab Controls
Motion Controllers
  • left hand of the first actor
  • right hand of the first actor
  • head hand of the first actor
  • left hand of the second actor
  • right hand of the second actor
  • head hand of the second actor
Or any subset of these items.
Animation Export
Using Import target character on Export tab you can import target character for active actor. If you want to import target character for the second actor, just make it active using buttons on toolbar and repeat importing. Target characters can be one and the same or different.
Export
Demo
