Starting from version 2.4, iPi Mocap Studio supports multi-person tracking with the following limitations:
- Currently only two actors tracking is available in the public release.
- Tracking of more than two actors requires more RnD and currently not feasible due to mutual occlusion of actors.
- At least 5 Sony PlayStation Eye cameras are required to track multiple actors.
- It's recommended to use 6 — 8 cameras to track multiple actors.
- For simple actions when actors are rarely close to each other you can use 4 — 5 Sony PlayStation Eye cameras or even two depth sensors (MS Kinect / ASUS Xtion / PrimeSense Carmine).
- For single depth sensor and for 3 web cameras multi-person tracking is not enabled.
- Multi-person tracking is available only in STANDARD edition. In other editions you can try this functionality but in this case all results will be saved in restricted trial format which prohibits export of result animation.
Actors Clothing
For color cameras:
- All regular recommendations.
- Plus it's highly recommended to use different colors for clothing of different actors. It will minimize tracking errors.
For depth sensors:
- Only regular recommendations. No additional recommendations, because current version of iPi Mocap Studio doesn't use color data from depth sensors during tracking (color data is used only for visualization).
Cameras Configuration
The main requirement is to minimize self- and mutual occlusions of actors. In general, 5 — 8 cameras should be placed in full-circle with at least two cameras at 2.5+ meters height. If you're going to use less cameras then all actions should be planned in such a way which minimize mutual actors occlusion. For example, screenshot below demonstrates how to capture two actors handshake with just two depth sensors:
T-pose
Processing
- During project creation you will need to specify number of actors and then parameters of each actor:
- At the toolbar you will see buttons for switching between actors. Also you can switch by clicking on actor model in the 3D view port. Skin of "inactive" actor is grayed. Content of Actor tab is displayed for the active actor.
- For each actor:
- Roughly align actor's model with actor's images in all cameras using Move, Rotation and IK tools
- Adjust actor parameters if needed
- Click Analyze Actor Appearance button
- Correct actor's colors with the aid of Eye dropper if needed
- Click Refit Pose on Tracking tab.
- Repeat steps starting from 3 if needed
- Adjust Region-of-Interest, choose tracking settings on the Tracking tab and execute tracking
- After processing you can use regular procedures for clean-up and post-processing.
Motion Controllers
- left hand of the first actor
- right hand of the first actor
- head of the first actor
- left hand of the second actor
- right hand of the second actor
- head of the second actor
Or any subset of these items.
Animation Export
Using Import target character on Export tab you can import target character for active actor. If you want to import target character for the second actor, just make it active using buttons on toolbar and repeat importing. Target characters can be one and the same or different.
Demo
