Revision as of 12:08, 19 September 2013 by VMaslov (Talk | contribs)
Why
Hand tracks in the timeline
Context menu of the key frame
However, when doing keyframing over mocap data, it is very convenient to have a video reference. Why not to do this right in the mocap software, which natively deals with video? Now you can. Meet the hand keyframing feature of iPi Mocap Studio.
Basics
  • Click Insert Key Frame for Right Hand or Insert Key Frame for Left Hand menu item from the context menu of the timeline
  • Going to the last frame (same as double click)
  • Setting one of the predefined poses like fist, relaxed etc. as well as recently used poses from files
  • Deleting this key frame
Advanced
Managing hand pose library
You may add your own hand poses to the list of standard poses present in the context menu for a keyframe. For that, you just need to save the hand pose somewhere in a file. 10 most recently saved/loaded/applied pose files are listed in the context menu for corresponding hand. To access older poses, use Edit > Load Pose from File to Clipboard menu item — the hand pose will be automatically placed to the context menu (replacing the oldest one from 10 items).
  • Setup the needed pose for fingers with the Rotate tool (or copy from another hand)
  • Select the appropriate hand bone (RHand or LHand)
  • Hit Edit > Copy Pose of Selected Bone's Children to copy the pose of fingers to the clipboard
  • Hit Edit > Save Pose to File from Clipboard to save the pose in a file
See also the video tutorial.
Transferring a pose from one hand to another
Notes
  • When manipulating with key frames, finger poses in all the frames involved in edit are automatically recomputed. However, as the keyframing feature is not mature yet, the software may fail to do it properly in some cases. As a workaround for such situations, there is the Recompute Finger Poses command in the context menu of the timeline. It forces the computation of finger poses in the whole animation from scratch based on existing key frames.
