USB controllers
- 2 depth sensors (MS Kinect, or ASUS Xtion, or PrimeSense Carmine)
USB hubs
Known compatibility issues
| ASUS Xtion (Live) | NEC µPD720200 (USB3) | Camera is not properly recognized by the system. | This firmware update makes device behave like PrimeSense Carmine 1.08 with the same controller (see below). |
| PrimeSense Carmine 1.08 | NEC µPD720200 (USB3) | Frame drops in 640x480@30 (depth + color). | Stable work in 640x480@30 (depth only) and 320x240 (depth + color). |
| PrimeSense Carmine 1.08 | VIA VT6212L (USB2) | Frame drops in 640x480@30 (depth + color). | Stable work in 640x480@30 (depth only) and 320x240 (depth + color). |
| PrimeSense Carmine 1.08 | VIA VL800(USB3) | Frame drops and reduced frame rate in depth + color modes. | Stable work in depth only modes. |
| Sony Playstation Eye | VIA VL800 (USB3) | Great number of bad frames and frame drops. Camera is invisible to iPi Recorder. | |
| Sony Playstation Eye | VIA VT6212L (USB2) | Great number of frame drop in 640x480@60 mode. | 2 cameras can work smoothly at lower FPS (up to 640x480@50). |
