USB controllers
Revision as of 13:04, 22 November 2013 by VMaslov (Talk | contribs)
USB hubs
Known compatibility issues
ASUS Xtion (Live) NEC µPD720200 (USB3) Camera is not properly recognized by the system. This firmware update makes device behave like PrimeSense Carmine 1.08 with the same controller (see below).
