Processing a video from a depth sensor
- Run iPi Mocap Studio
- Press Ctrl+N or push New button on toolbar to create new project
- Choose recorded *.iPiVideo file
- Right mouse button up
- Save created project by pressing Ctrl+S or pushing button Save on toolbar
- Adjust actor height using appropriate slider on tab Actor
- Select Move tool on toolbar.
- Switch to Tracking tab and push Refit pose button.
- As a result model should be matched with actor image from video. If it does not happen then delete result using item Edit > Delete pose from main menu and repeat above actions.
- Using the slider right to the button Show Skin in toolbar, make sure that morph of model corresponds to the actor image. If no, than adjust chest/bust/waist/hips/belly morph using appropriate sliders from Actor tab.
- Switch to Tracking tab, change tracking options (Head tracking, Shoulders and Spine) if required.
- To start tracking just push Track Forward button.
- Wait and watch...
