Cameras and accessories
- Very good low-light sensitivity.
- Low-distortion wide-angle fixed optics.
- Efficient protocol for image transfer (saves more than 50% of USB bandwidth when compared to other webcams).
- Low cost (under $40).
Cables
Tripods
Video Card
iPi Desktop Motion Capture relies on GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Intel integrated graphics is not supported
Please be aware that desktop GPUs are dramatically faster than notebook GPUs (due to apparent thermal constraints in notebook PCs).
USB controllers
- 2 depth sensors (MS Kinect, or ASUS Xtion, or PrimeSense Carmine)
USB hubs
Known compatibility issues
| ASUS Xtion (Live) | NEC µPD720200 (USB3) | Camera is not properly recognized by the system. | This firmware update makes device behave the same as PrimeSense Carmine 1.08 with this controller. |
| ASUS Xtion (Live) | VIA VT6212L (USB2) | Frame drops of color picture in 640x480@30 (depth + color). | |
| PrimeSense Carmine 1.08 | NEC µPD720200 (USB3) | Frame drops in 640x480@30 (depth + color). | Stable work in 640x480@30 (depth only) and 320x240 (depth + color). |
| PrimeSense Carmine 1.08 | VIA VT6212L (USB2) | Frame drops in 640x480@30 (depth + color). | Stable work in 640x480@30 (depth only) and 320x240 (depth + color). |
| PrimeSense Carmine 1.08 | VIA VL800(USB3) | Frame drops, reduced frame rate, freezes in depth + color modes. | Stable work in depth only modes. |
| Sony Playstation Eye | VIA VL800 (USB3) | Great number of bad frames and frame drops. Camera is invisible to iPi Recorder. | |
| Sony Playstation Eye | VIA VT6212L (USB2) | Great number of frame drop in 640x480@60 mode. | 2 cameras can work smoothly at lower FPS (up to 640x480@50). |
