Cameras and accessories
Revision as of 16:49, 21 July 2014 by Pavel (Talk | contribs)
  • Low cost (under $40).
Cables
Tripods
Video Card
iPi Desktop Motion Capture relies on GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Intel integrated graphics is not supported
Please be aware that desktop GPUs are dramatically faster than notebook GPUs (due to apparent thermal constraints in notebook PCs).
USB controllers
USB hubs
Known compatibility issues
