Laptops with switchable graphics
Many modern laptops come with the switchable graphics technology. There are two graphics chips inside, one is a low-power integrated GPU and another is a high-performance discrete GPU. When running iPi Mocap Studio on such laptops, you need to ensure that it uses a discrete GPU, otherwise the performance will be poor.
Some laptop models have physical button to switch between GPUs. But on most models, this is configured in the graphics control panel. For NVIDIA-based laptops it's NVIDIA Control Panel, for AMD-based it's Catalyst Control Center. There you can usually set either global usage of high-performance GPU for all programs, or specify a GPU to be used on per-program basis.
A control panel may allow you to choose the program to configure from a list of installed programs, or from a list of running programs. If none of these options is available, then you'll need to get the full path to executable file of iPi Mocap Studio. A simple way to find it out is to:
- run iPi Mocap Studio
- open Task Manager application
- locate process iPiMocapStudio.exe
- right-click on it and choose Open File Location
Note. iPi Mocap Studio is deployed using the ClickOnce technology, therefore a directory where its executable is located may change after the application updates. Thus, it may be required to reconfigure GPU usage for iPi Mocap Studio after some updates.
