IPi Recorder 1.x Installation
Revision as of 14:51, 9 December 2011 by Pavel (Talk)
  • unplug MS Kinect Sensor or Sony PS Eye cameras from computer
iPi Recorder is a tool for recording video from web cameras and depth sensors. Download the setup package of iPi Recorder latest version: http://ipisoft.com/downloads/iPiRecorderSetup.exe. Run it. In the following dialog window make sure that
  • item “PrimeSensor Driver (psdrv3) Registration for MS Kinect Sensor” is selected if you plan to work with Kinect
  • item “WinUSB Driver Registration for PS3 Eye Camera” is selected if you plan to work with Sony PS Eye cameras
Note that if you do not plan to use Sony PlayStation Eye cameras or Kinect then you can deselect the appropriate item in the list.
Click “Install” button to start the installation process. You’ll be asked about drivers installation:
At this point the drivers will complete installation and should not give any other errors:
After that, connect MS Kinect Sensor or Sony PS3 Eye cameras to your PC. Under Windows Vista and Windows 7 device initialization should be performed automatically and you’ll receive notification about it in the system tray area. Under Window XP you’ll be asked several times:
In all cases answer “No, not this time” and “Install the software automatically (Recommended)” respectively:
