IPi Recorder Installation p2 Dual Kinect
Select both items “MS Kinect Sensor (OpenNI)” and press “Ok” button. Make sure that you can see colored “depth video” from both sensors, that actual frame rate is 30 fps, that frames drop is in range from 0 to 5 and that you can change motor position using appropriate slider:
- Note that values of Tilt and Roll are updated with a time lag. During recording these values cannot be updated assuming that in this case sensor should be static.
