IPi Recorder Installation p2 Dual Kinect
Revision as of 16:57, 9 December 2011 by Pavel (Talk)
Run iPi Recorder and make sure that there are two items “MS Kinect Sensor (OpenNI)” in “Camera Selector” dialog:
Select both items “MS Kinect Sensor (OpenNI)” and press “Ok” button. Make sure that you can see colored “depth video” from both sensors, that actual frame rate is 30 fps, that frames drop is in range from 0 to 5 and that you can change motor position using appropriate slider:
