IPi Recorder Installation p2 Dual Kinect
Revision as of 12:29, 12 December 2011 by Pavel (Talk)
Good
Bad
Run iPi Recorder and make sure that there are two items “MS Kinect Sensor (OpenNI)” in “Camera Selector” dialog:
Select both items “MS Kinect Sensor (OpenNI)” and press “Ok” button. As a result you should see something like this:
