Our user cra0calo created an example Valve Biped rig for use with 3D MAX. It may be useful if you work with Valve Source Engine characters.
Current version of iPi Studio does not support FBX format, but you can use Autodesk's free FBX Converter to convert your data between FBX and COLLADA format. COLLADA is fully supported in iPi Studio and many other 3D graphics applications. COLLADA has similar features to FBX.
Recommended format for importing target characters from LightWave to iPi Studio is COLLADA. Recommended format for bringing animations from iPi Studio to LightWave is BVH. In case if you encounter incompatibilities during import/export we recommend using Autodesk's free FBX Converter to convert your data between FBX and COLLADA formats.
Animeeple
- Click “Set first frame” on the “TPose” tab in import dialog.
- Assign bone mappings on the “Bones” tab:
| Segment | Bone |
| Hip | Hips |
| LowerSpine | --- |
| MiddleSpine | --- |
| Chest | Torso |
| Neck | Neck |
| Head | Head |
| Head|Site | --- |
| (R/L)Clavicle | Collar |
| (R/L)Shoulder | Upper arm |
| (R/L)Forearm | Lower arm |
| (R/L)Hand | Hand |
| (R/L)Hand|Site | --- |
| (R/L)Thigh | Upper leg |
| (R/L)Shin | Lower leg |
| (R/L)Foot | Foot |
| (R/L)Toe | Toe base |
| (R/L)Toe|Site | --- |
- Set the scale to 0.01 on the “Size” tab (by default, iPi Studio exports translations in centimeters for BVH files, while Animeeple expects translations in meters).
- Set “Root position: Y:” to a correct value on the “TPose” tab, or click “Drop to floor”.
Our user cra0calo created an example Valve Biped rig for use with 3D MAX. It may be useful if you wish to apply more then one capture through MotionBuilder or edit the custom keyframes in MAX.
iPi Studio supports importing of skinned Evolver characters in COLLADA format. Import your Evolver character skeleton into iPi Studio (File->Import Target Character). Your animation will be retargeted to your Evolver character. Now you can use File->Export Animation to export your animation.
