Performance Kinect
Revision as of 16:28, 13 December 2011 by Pavel (Talk)
Recording Actor's Performance
Performance Tips
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
Recording Process
