Revision as of 22:24, 11 March 2011 by Mini (Talk)
Current version of iPi Studio does not support FBX format, but you can use Autodesk's free FBX Converter to convert your data between FBX and COLLADA format. COLLADA is fully supported in iPi Studio and many other 3D graphics applications. COLLADA has similar features to FBX.
Recommended format for importing target characters from LightWave to iPi Studio is COLLADA. Recommended format for bringing animations from iPi Studio to LightWave is BVH. In case if you encounter incompatibilities during import/export we recommend using Autodesk's free FBX Converter to convert your data between FBX and COLLADA formats.
Step 5
Step 5
Animeeple
SegmentBone
HipHips
 LowerSpine---
  MiddleSpine---
   ChestTorso
    NeckNeck
     HeadHead
      Head|Site---
    (R/L)ClavicleCollar
     (R/L)ShoulderUpper arm
      (R/L)ForearmLower arm
       (R/L)HandHand
        (R/L)Hand|Site---
 (R/L)ThighUpper leg
  (R/L)ShinLower leg
   (R/L)FootFoot
    (R/L)ToeToe base
     (R/L)Toe|Site---
Step 5
iPi Studio supports importing of skinned Evolver characters in COLLADA format. Import your Evolver character skeleton into iPi Studio (File->Import Target Character). Your animation will be retargeted to your Evolver character. Now you can use File->Export Animation to export your animation.
