Open multi-camera video in iPi Studio. Load scene configuration from file.
Adjust the Background Region and Region of Interest. (Region of Interest should cover the part of video that contains the motion).
Go to T-pose frame. Using character move/rotate controls, roughly align the model with the image of actor in one view. Adjust character height (on “Actor” tab) to correspond to actor height. Push the “Analyze Appearance” button on “Actor” tab. For the multi-camera video, “Analyze Appearance” button uses only one (current) camera. This makes it easier to align model with image. You can refine actor appearance by alternating “Refit Pose” and “Analyze Appearance”.
Go to the first frame of Region of Interest. Push the “Refit Pose” button on “Tracking” tab. If initial pose was recognized incorrectly, you can roughly adjust it manually and use auto-fit again.
Push the “Track Forward” button on “Tracking” tab.
You can save your motion capture project to a file. If your project is saved to a file, then the system will auto-save it after each processed frame during tracking.
Refer to video tutorial for tips on video processing:
