Revision as of 18:32, 12 October 2011 by Andrew (Talk)
  BETA STATUS
Prerequisites
Note that before starting of working with two Kinects it's highly recommended to get appropriate results with single Kinect solution: Quick Start Guide with MS Kinect Sensor.
Recording with 2 Kinects
Important! Each Kinect Sensor should be plugged through different USB controllers. If both Kinects are plugged through one and the same USB controller then the second Kinect will not work. How it looks in the Device Manager:
Good
Bad
Note that you can turn off RGB streaming using appropriate checkbox in the Advanced Options section of Camera Selector dialog. Also you can change correspondence between cameras and motors in case when they are in the wrong order:
Don't forget to set output directory for recorded video:
Calibration
Preparations
  2. angle between sensors in near to 180 degrees that is sensors are opposite to each other.
At present time we strongly recommend to use the first configuration:
Top view
Side view
  • make sure that this calibration plane is good visible in the both sensors (the amount of yellow is low in the area of the veneer/plywood/cardboard/pasteboard).
Good
Bad
good size
good depth data
too small
too close to human body
Important! Yellow color in the depth map means "depth here is unknown". Thus it is important to minimize amount of yellow points using appropriate materials and clothes.
Recording
After preparations and sensors setup record the calibration video:
  • Go to the capture volume with prepared calibration plane (flat rectangular veneer/plywood/cardboard/pasteboard).
Good
Bad
Open resulted video in the iPi Studio and check the following:
  • At least first two seconds of video contains only background and static objects (no actor, no calibration plane)
  • The calibration plane are moving and has at least 30 degrees variety in the horizontal view angle
  • The amount of yellow points is rather small
Processing
  • Make sure that ground plane is determined correctly for both sensor after calibration video opening in the iPi Studio (to switch between sensors use buttons "Camera 1" and "Camera 2" in the top toolbar).
  • Set the beginning of Region of Interest (ROI) to the point where calibration plane is good visible in the both sensors.
  • Adjust the end of ROI:
    • the length of ROI should be at leat 5 sec (150 frames)
  • Wait for the end of calculations
  • Evaluate the result:
  • Save the result:
    • go to the Scene tab
Tracking
Next Steps
