BETA STATUS |
Prerequisites
- for more info see USB controllers
- Storage system: HDD or SSD or RAID with write speed at least 55 Mb/sec
- iPi Recorder 1.6.0.121 or later
- see Quick Start Guide with MS Kinect Sensor#iPi_Recorder for installation instructions
- iPi Studio 1.3.0.79 or later (Free Trial or Basic or Standard edition)
- see Quick Start Guide with MS Kinect Sensor#iPi_Studio for installation instructions
- Two Microsoft Kinect Sensors with separate power adapters
Drivers Update
- PSensor_iPi-x86.msi for 32bit Windows
- PSensor_iPi-x64.msi for 64bit Windows
Recording with 2 Kinects
- that you can change motor position for each sensor using appropriate slider and “Motor of” combobox
- that you can switch between RGB and “depth” video using “View RGB/Depth” button
- that actual frame rate is 30 fps (or 29.9) and frames drop is in range from 0 to 5 for each sensor
Note that you can turn off RGB streaming using appropriate checkbox in the Advanced Options section of Camera Selector dialog. Also you can change the position of cameras and motors in the interface in case they are positioned in the wrong order:
Calibration
Preparations
- angle between sensors in near to 180 degrees that is sensors are opposite to each other.
At present time we strongly recommend to use the first configuration:
- make sure that this calibration plane is good visible in the both sensors (the amount of yellow is low in the area of the veneer/plywood/cardboard/pasteboard).
Important! Yellow color in the depth map means "depth here is unknown". Thus it is important to minimize amount of yellow points using appropriate materials and clothes.
Recording
After preparations and sensors setup record the calibration video:
- Start recording by pressing the "Start Video Recording" button.
- Initial two seconds of video should contain only background and static objects. Presence of actor or any moving objects in the initial two seconds of recorded video is unacceptable.
- Go to the capture volume with prepared calibration plane (flat rectangular veneer/plywood/cardboard/pasteboard).
- Turn the veneer/plywood/cardboard/pasteboard to the left and to the right thus view angle is changing but the veneer/plywood/cardboard/pasteboard is still visible in both sensors.
- Stop the recording by pressing the "Stop Video Recording" button.
Open resulted video in the iPi Studio and check the following:
- At least first two seconds of video contains only background and static objects (no actor, no calibration plane)
- The calibration plane is good visible on the depth maps most the time
- The calibration plane are moving and has at least 30 degrees variety in the horizontal view angle
- The amount of yellow points is rather small
Processing
- Make sure that ground plane is determined correctly for both sensor after calibration video opening in the iPi Studio (to switch between sensors use buttons "Camera 1" and "Camera 2" in the top toolbar).
- Set the beginning of Region of Interest (ROI) to the point where calibration plane is good visible in the both sensors.
- Adjust the end of ROI:
- the length of ROI should be at leat 5 sec (150 frames)
- Go to the Calibration tab, select "Angle between sensors is 30 - 90 degrees" option and click "Calibrate Based on 3D Plane" button
- Wait for the end of calculations
- Evaluate the result:
- Save the result:
- go to the Scene tab
Tracking
Recording and processing of performance video is mostly like ones for single Kinect solution: Quick Start Guide with MS Kinect Sensor#Processing Video from Depth Sensor.
The main difference is that after loading of performance video into iPi Studio you should load your scene parameters:
- switch to the Scene tab
- select file with scene parameters which was saved during calibration process
- etc.
