Revision as of 18:18, 14 October 2011 by Pavel (Talk)
  BETA STATUS
Prerequisites
Drivers Update
Recording with 2 Kinects
Good
Bad
Calibration
Preparations
  2. angle between sensors in near to 180 degrees that is sensors are opposite to each other.
At present time we strongly recommend to use the first configuration:
Top view
Side view
  • make sure that this calibration plane is good visible in the both sensors (the amount of yellow is low in the area of the veneer/plywood/cardboard/pasteboard).
Good
Bad
good size
good depth data
too small
too close to human body
Important! Yellow color in the depth map means "depth here is unknown". Thus it is important to minimize amount of yellow points using appropriate materials and clothes.
Recording
After preparations and sensors setup record the calibration video:
  • Go to the capture volume with prepared calibration plane (flat rectangular veneer/plywood/cardboard/pasteboard).
Good
Bad
Open resulted video in the iPi Studio and check the following:
  • At least first two seconds of video contains only background and static objects (no actor, no calibration plane)
  • The calibration plane are moving and has at least 30 degrees variety in the horizontal view angle
  • The amount of yellow points is rather small
Processing
  • Make sure that ground plane is determined correctly for both sensor after calibration video opening in the iPi Studio (to switch between sensors use buttons "Camera 1" and "Camera 2" in the top toolbar).
  • Set the beginning of Region of Interest (ROI) to the point where calibration plane is good visible in the both sensors.
  • Adjust the end of ROI:
    • the length of ROI should be at leat 5 sec (150 frames)
  • Wait for the end of calculations
  • Evaluate the result:
  • Save the result:
    • go to the Scene tab
Tracking
Recording and processing of performance video is mostly like ones for single Kinect solution: Quick Start Guide with MS Kinect Sensor#Processing Video from Depth Sensor.
The main difference is that after loading of performance video into iPi Studio you should load your scene parameters:
  • switch to the Scene tab
  • select file with scene parameters which was saved during calibration process
  • etc.
Next Steps
