Revision as of 18:29, 14 October 2011 by Pavel (Talk)
  BETA STATUS
Prerequisites
Drivers Update
Recording with 2 Kinects
Good
Bad
Calibration
Preparations
For current version we strongly recommend to use the first configuration:
Top view
Side view
  • make sure that this calibration plane is good visible in both sensors (the amount of yellow is low in the area of the veneer/plywood/cardboard/pasteboard).
Good
Bad
good size
good depth data
too small
too close to human body
Recording
Good
Bad
Processing
  • Adjust the end of ROI:
  • Evaluate the result:
  • Save the result:
    • go to the Scene tab
Tracking
Recording and processing of performance video is generally the same as for single Kinect solution: Quick Start Guide with MS Kinect Sensor#Processing Video from Depth Sensor.
  • switch to the Scene tab
  • etc.
Next Steps
