Revision as of 16:11, 8 April 2011 by Mini (Talk)
Latest versions of Maya (starting with Maya 2011) have a powerful biped animation subsystem called "HumanIK". Animations exported from iPiStudio in MotionBuilder-friendly format should work fine with Maya 2011 and HumanIK. The following video tutorial from Autodesk can be helpful: Non-Destructive Live Retargeting — Maya 2011 New Features
For older versions of Maya please see the #Motion Transfer and Custom Rigs section.
Current version of iPi Studio does not support FBX format, but you can use Autodesk's free FBX Converter to convert your data between FBX and COLLADA format. COLLADA is fully supported in iPi Studio and many other 3D graphics applications. COLLADA has similar features to FBX.
Recommended format for importing target characters from LightWave to iPi Studio is COLLADA. Recommended format for bringing animations from iPi Studio to LightWave is BVH. In case if you encounter incompatibilities during import/export we recommend using Autodesk's free FBX Converter to convert your data between FBX and COLLADA formats.
Step 5
Step 5
Animeeple
SegmentBone
HipHips
 LowerSpine---
  MiddleSpine---
   ChestTorso
    NeckNeck
     HeadHead
      Head|Site---
    (R/L)ClavicleCollar
     (R/L)ShoulderUpper arm
      (R/L)ForearmLower arm
       (R/L)HandHand
        (R/L)Hand|Site---
 (R/L)ThighUpper leg
  (R/L)ShinLower leg
   (R/L)FootFoot
    (R/L)ToeToe base
     (R/L)Toe|Site---
Step 5
iPi Studio supports importing of skinned Evolver characters in COLLADA format. Import your Evolver character skeleton into iPi Studio (File->Import Target Character). Your animation will be retargeted to your Evolver character. Now you can use File->Export Animation to export your animation.
