Revision as of 18:05, 25 November 2011 by Andrew (Talk)
Prerequisites
Drivers Update
Recording with 2 Kinects
Good
Bad
Calibration
The first configuration
Top view
Side view
Preparations
Good
Bad
good size
good depth data
too small
too close to human body
Recording
Good
Bad
Processing
  • Adjust the end of ROI:
  • Evaluate the result:
  • Save the result:
    • go to the Scene tab
Video tutorial from TrueBones
The second configuration
Top view
Side view
Preparations
Recording
Good
Bad
Processing
Tracking
Recording and processing of performance video is generally the same as for single Kinect solution: Quick Start Guide with MS Kinect Sensor#Processing Video from Depth Sensor.
  • switch to the Scene tab
  • etc.
Next Steps
Materials
Video
Users' Feedback
Brilliant work guys.
than with a single Kinect.
I am utterly astonished.
