Revision as of 13:46, 27 December 2011 by Pavel (Talk)
For the impatient:
  • Get two Microsoft Kinect Sensors with separate power adapters and computer with DirectX 10 videocard
  • Download and install iPiRecorder and iPiStudio
  • Connect Kinects to PC, point them at the actor (the angle between two Kinects can be in the range 60-90 degrees, or near to 180 degrees)
  • Please ensure that the calibration board is visible in both sensors. Initial 1-2 seconds of video should contain only background and static objects. Turn the calibration board to the left and to the right, holding it vertically in front of yourself on outstretched arms.
  • Record video of actor's performance. Please ensure that the whole body including arms and legs is visible during the performance in both sensors. First 1-2 seconds of video should contain background only (no actor). Then goes a T-pose. Then goes actor’s performance.
  • Run iPi Studio to process actor performance video
  • Import your character into iPi Studio (File->Import Target Character) to adapt the animation for your character rig
For more details see User Guide for Dual Kinect Sensor Configuration.
