- Video card: Direct3D 10-capable (Shader Model 4.0) gaming-class graphics card (GeForce GTS 250 or Radeon HD 4850 or better recommended)
- Microsoft Kinect Sensor (“Depth Sensor”)
Software Installation
- Note that if you have used iPi Recorder before than you also need to perform these actions rather than just let iPi Recorder to be updated automatically. It is because drivers for MS Kinect Sensor must also be installed.
- Note that if you aren’t going to use Sony PlayStation Eye cameras then you can deselect the appropriate item in list.
Click “Install” button to start installation process. During will process you’ll be asked about installation of “iPi LibUSB-win32 Driver Registration for MS Kinect Sensor”:
After that, connect MS Kinect Sensor to your PC. Under Windows Vista and Windows 7 device initialization should be performed fully automatic and you’ll receive notification about it in the system tray area.
- “Can Windows connect to Windows Update to search for software?”
- “What do you want the wizard to do?”
- Note that values of Tilt and Roll are update with some time lag. And during recording these values are not updated at all assuming that in this case sensor should be static.
iPi Studio
- Note that if you have used iPi Studio before and have Internet connection on your computer than all you need is to let iPi Studio to automatically update:
iPi Studio is a core software of iPi Desktop Motion Capture (iPi DMC) solution. It’s used to process pre-recorded video and export result animation in most popular formats. You can use 30 days free trial.
To install iPi Studio just download and run setup program: http://ipisoft.com/downloads/iPiStudioSetup.exe. Then, follow instructions on screen.
To obtain trial key please register to our user forum following the link http://ipisoft.com/forum/ucp.php?mode=register. After registration take trial license key from forum’s “User Control Panel”:
- Note that if you don’t receive activation e-mail after registration then:
- Make sure that this e-mail is not in “Spam” folder of your mail client.
- Check that you have entered correct e-mail address.
- Try to resend activation email. To do it, go to login page and click “Resend activation e-mail” link.
Ok, after all these preparations you are ready for performance.
It is convenient to put MS Kinect Sensor on chair or table. The following drawing should provide you with some information about possible capture area and required space:
- Important! Fist two seconds of video should contain only background and static objects. That is presence of actor or some moving object in first two seconds of recorded video is unacceptable. It’s because first seconds of video are used to calculate static background which is used to separate actor from other elements of 3D scene.
- Note that current version uses only depth information to track motions. Thus there is not any restrictions on clothing colors (just avoid shiny fabrics). But it is desirable that actor wears tightly to reduce noise in result animation.
