Revision as of 16:10, 21 February 2011 by Andrew (Talk)
  • Microsoft Kinect Sensor (“Depth Sensor”)
Software Installation
Note that if you have used iPi Recorder before than you also need to perform these actions rather than just let iPi Recorder to be updated automatically. It is because drivers for MS Kinect Sensor must also be installed.
iPi Recorder is a tool for recording video from web cameras and depth sensors. Download setup package of the latest version of iPi Recorder: http://ipisoft.com/downloads/iPiRecorderSetup.exe. Run it. In the following dialog window make sure that item “LibUSB-win32 Driver Registration for MS Kinect Sensor” is selected:
Note that if you aren’t going to use Sony PlayStation Eye cameras then you can deselect the appropriate item in list.
Click “Install” button to start installation process. During will process you’ll be asked about installation of “iPi LibUSB-win32 Driver Registration for MS Kinect Sensor”:
Read license agreement and accept it by checking appropriate checkbox. Then press “Install” button. When you get the Windows Security screen, select “Install this driver software anyway”:
At this point the driver will complete the driver installation and should not give any other errors:
After that, connect MS Kinect Sensor to your PC. Under Windows Vista and Windows 7 device initialization should be performed fully automatic and you’ll receive notification about it in the system tray area. Under Window XP you’ll be asked three times (for “Xbox NUI Motor”, “Xbox NUI Audio” and “Xbox NUI Camera”):
Note that values of Tilt and Roll are update with some time lag. And during recording these values are not updated at all assuming that in this case sensor should be static.
iPi Studio
Note that if you have used iPi Studio before and have Internet connection on your computer than all you need is to let iPi Studio to automatically update:
iPi Studio is a core software of iPi Desktop Motion Capture (iPi DMC) solution. It’s used to process pre-recorded video and export result animation in most popular formats. You can use 30 days free trial. To install iPi Studio just download and run setup program: http://ipisoft.com/downloads/iPiStudioSetup.exe. Then, follow instructions on screen.
To obtain trial key please register to our user forum following the link http://ipisoft.com/forum/ucp.php?mode=register. After registration take trial license key from forum’s “User Control Panel”:
Ok, after all these preparations you are ready for performance.
It is convenient to put MS Kinect Sensor on chair or table. The following drawing should provide you with some information about possible capture area and required space:
Side view
Top view
Start iPi Recorder and choose “MS Kinect Sensor” in Camera Selector dialog:
Using “Motor” slider, adjust direction of sensor so that at the bottom of image floor is present and actor is visible in full length (with hands up if needed):
Important! Fist two seconds of video should contain only background and static objects. That is presence of actor or some moving object in first two seconds of recorded video is unacceptable. It’s because first seconds of video are used to calculate static background which is used to separate actor from other elements of 3D scene.
As soon as recorder started and “clear” scene is recorded for a couple of seconds, go to the capture area and stand in a T-pose:
Note that current version uses only depth information to track motions. Thus there is not any restrictions on clothing colors (just avoid shiny fabrics). But it is desirable that actor wears tightly to reduce noise in result animation.
Using Windows Explorer, go to destination folder and open recorded file with name <c>video_YYYY-MM-DD_hh-mm-ss.avi</c> in Windows Media Player. You should see depth information as a blue image:
Clean-up
Frequently Asked Question
