- Video card: Direct3D 10-capable (Shader Model 4.0) gaming-class graphics card (GeForce GTS 250 or Radeon HD 4850 or better recommended)
- Microsoft Kinect Sensor (“Depth Sensor”)
Software Installation
- Note that even if you have used iPi Recorder before you will need to perform actions below anyway. Just letting iPi Recorder to be updated automatically will not work, because drivers for MS Kinect Sensor must be installed in addition.
- Note that if you do not plan to use Sony PlayStation Eye cameras then you can deselect the appropriate item in the list.
- “Can Windows connect to Windows Update to search for software?”
- “What do you want the wizard to do?”
- Note that values of Tilt and Roll are updated with a time lag. During recording these values cannot be updated assuming that in this case sensor should be static.
iPi Studio
- Note that if you don’t receive activation e-mail after registration then:
- Make sure that this e-mail is not in “Spam” folder of your mail client.
- Check that you have entered correct e-mail address.
- Try to resend activation email. To do it, go to login page and click “Resend activation e-mail” link.
- If none of above actions help, please report the problem to ipi@ipisoft.com.
Ok, after all these preparations you are ready for performance.
It is convenient to put MS Kinect Sensor on chair or table. The following drawing should provide you with some information about possible capture area and required space:
- Important! Fist two seconds of video should contain only background and static objects. That is presence of actor or some moving object in first two seconds of recorded video is unacceptable. It’s because first seconds of video are used to calculate static background which is used to separate actor from other elements of 3D scene.
- Note that current version uses only depth information to track motions. Thus there is not any restrictions on clothing colors (just avoid shiny fabrics). But it is desirable that actor wears tightly to reduce noise in result animation.
