Revision as of 19:23, 21 February 2011 by Andrew (Talk)
  • Microsoft Kinect Sensor (“Depth Sensor”)
Software Installation
iPi Studio
Side view
Top view
Please start iPi Recorder and choose “MS Kinect Sensor” in Camera Selector dialog:
Using Windows Explorer, go to destination folder and open the recorded file with name <c>video_YYYY-MM-DD_hh-mm-ss.avi</c> in Windows Media Player. You should see depth information as a blue image:
Next steps
Frequently Asked Questions
