Revision as of 21:48, 21 February 2011 by Andrew (Talk)
  • Microsoft Kinect Sensor (“Depth Sensor”)
Software Installation
iPi Studio
Side view
Top view
Please start iPi Recorder and choose “MS Kinect Sensor” in Camera Selector dialog:
  • Run iPi Studio
  • Choose recorded avi file
  • In the “Select Video Layout” dialog prefer the following values:
    • Numbers of cameras: 1
    • Resolution: 640x480
  • After video opening, background will be calculated automatically and position of camera will be detected based on floor plane.
    3. Right mouse button up
    4. Visually control that 3d points from floor are located on ground plane which is denoted by squared grid
Note that you always can come back to the camera point of view by pressing 1 key on keyboard or pushing “Camera 1” button on toolbar
  • Save created project to the file by pressing Ctrl+S or pushing button “Save” on toolbar
  • Dragging timeline slider to frame where actor is in T-pose
  • Move actor model to left or right to approximately fit with actor silhouette on video. Note that actor model can look smaller due to its position along axis of view. Don’t pay attention to it on this step.
  • As a result model should be feted with actor image from video. If it does not happen then delete result using item “Edit” -> “Delete pose” from main menu and repeat actions.
  • Using slider right from button “Show Skin” in toolbar, make sure that morph of model corresponds to the actor image. If no, than adjust arms/torso/legs morph using appropriate sliders from “Actor” tab.
  • Set begging of Region-of-Interest (ROI) to the current frame with T-pose by pressing I key on keyboard or by double-clicking on the left edge of ROI bar under timeline.
  • Wait and watch...
Next steps
Frequently Asked Questions
