BETA STATUS |
- Video card: Direct3D 10-capable (Shader Model 4.0) gaming-class graphics card (GeForce GTS 250 or Radeon HD 4850 or better recommended)
- Microsoft Kinect Sensor (“Depth Sensor”)
Software Installation
- Note that even if you have used iPi Recorder before you will need to perform actions below anyway. Just letting iPi Recorder to be updated automatically will not work, because drivers for MS Kinect Sensor must be installed in addition.
- Note that if you do not plan to use Sony PlayStation Eye cameras then you can deselect the appropriate item in the list.
- “Can Windows connect to Windows Update to search for software?”
- “What do you want the wizard to do?”
- Note that values of Tilt and Roll are updated with a time lag. During recording these values cannot be updated assuming that in this case sensor should be static.
iPi Studio
- Note that if you don’t receive activation e-mail after registration then:
- Make sure that this e-mail is not in “Spam” folder of your mail client.
- Check that you have entered correct e-mail address.
- Try to resend activation email. To do it, go to login page and click “Resend activation e-mail” link.
- If none of above actions help, please report the problem to ipi@ipisoft.com.
- Important! Initial two seconds of video should contain only background and static objects. Presence of actor or any moving objects in the initial two seconds of recorded video is unacceptable. It’s because initial seconds of video are used to calculate static background necessary to separate actor from other objects of 3D scene.
- Note that current version uses only depth information to track motions. So there are no restrictions on clothes colors (just avoid shiny fabrics). Please use slim clothes to reduce noise in resulted animation.
- Run iPi Studio
- Press Ctrl+O or push “Open” button on toolbar
- Choose recorded avi file
- In the “Select Video Layout” dialog prefer the following values:
- Depth video from MS Kinect Camera
- Numbers of cameras: 1
- Resolution: 640x480
- After video opening, background will be calculated automatically and position of camera will be detected based on floor plane.
- Right mouse button up
- Visually control that 3d points from floor are located on ground plane which is denoted by squared grid
- Note that you always can come back to the camera point of view by pressing 1 key on keyboard or pushing “Camera 1” button on toolbar
- Save created project to the file by pressing Ctrl+S or pushing button “Save” on toolbar
- Dragging timeline slider to frame where actor is in T-pose
- Move actor model to left or right to approximately fit with actor silhouette on video. Note that actor model can look smaller due to its position along axis of view. Don’t pay attention to it on this step.
- Switch to “Tracking” tab and push “Refit pose” button.
- As a result model should be feted with actor image from video. If it does not happen then delete result using item “Edit” -> “Delete pose” from main menu and repeat actions.
- Using slider right from button “Show Skin” in toolbar, make sure that morph of model corresponds to the actor image. If no, than adjust arms/torso/legs morph using appropriate sliders from “Actor” tab.
- Set begging of Region-of-Interest (ROI) to the current frame with T-pose by pressing I key on keyboard or by double-clicking on the left edge of ROI bar under timeline.
- Switch to “Tracking” tab, check “Enable foot tracking” and “Enable shoulders tracking” checkboxes
- To start tracking just push “Track Forward” button
- Wait and watch...
Next steps
Frequently Asked Questions
Q: Is tracking realtime?
A: No. You should record video first and after that process video offline. Speed of processing depends on model of Graphics Card and very from 5 to 0.25 frames per second.
A: No.
Q: Are hands/fingers tracked by iPi DMC?
A: No.
A: Also no. We plan to add head tracking in future versions.
Q: And what about FBX?
A: No. You should deinstall OpenNI drivers for Kinect if want to install iPi Recorder.
Q: Do you plan add support for OpenNI?
Q: What does "iPi DMC" means?
A: "iPi DMC" is abbreviation for "iPi Desktop Motion Caption". It consists of several programs among which:
- iPi Recorder - tool for recording video from web cameras and depth sensors;
Q: Is there version for Mac?
Q: How can I buy?
