Revision as of 23:30, 10 March 2011 by Andrew (Talk)
  BETA STATUS
Software Installation
iPi Studio
Side view
Top view
  • Run iPi Studio
  • Choose recorded avi file
    • Numbers of cameras: 1
    • Resolution: 640x480
    3. Right mouse button up
  • Wait and watch...
Next Steps
Video Materials
Frequently Asked Questions
Q: Is tracking realtime?
A: No.
A: COLLADA, BVH, SMD. Also iPi DMC can export BVH optimized for 3d Max Biped, Poser, MotionBuilder and iClone. For more info see Animation export and motion transfer
Q: And what about FBX?
A: We use driver from PrimeSense (psdrv3.sys) and OpenNI library to communicate with device via USB. Protocol implementation is our own.
Q: What does "iPi DMC" means?
Q: Is there version for Mac?
Q: How can I buy?
