Revision as of 18:28, 22 March 2011 by Andrew (Talk)
Software Installation
iPi Studio
Side view
Top view
  • Run iPi Studio
  • Choose recorded avi file
    • Numbers of cameras: 1
    • Resolution: 640x480
    3. Right mouse button up
  • Wait and watch...
Next Steps
Video Materials
Demo video
Video Tutotial from dueyftw
"First capture using Kinect" from GMM
  • Note that GMM forgot to turn on the foot tracking ("Tracking" tab), as a result foot sliding is present.
"First results" from Radiac
See also:
Frequently Asked Questions
Q: Is tracking realtime?
A: No.
A: COLLADA, BVH, SMD. Also iPi DMC can export BVH optimized for 3d Max Biped, Poser, MotionBuilder and iClone. For more info see Animation export and motion transfer
Q: And what about FBX?
A: We use driver from PrimeSense (psdrv3.sys) and OpenNI library to communicate with device via USB. Protocol implementation is our own.
Q: What does "iPi DMC" means?
Q: Is there version for Mac?
Q: How can I buy?
A: You can buy online.
