- Video card: Direct3D 10-capable (Shader Model 4.0) gaming-class graphics card (GeForce GTS 250 or Radeon HD 4850 or better recommended)
- Microsoft Kinect Sensor (“Depth Sensor”) with separate power adapter
Software Installation
- Note that even if you have used iPi Recorder before you will need to perform actions below anyway. Just letting iPi Recorder to be updated automatically will not work, because drivers for MS Kinect Sensor must be installed in addition.
- unplug MS Kinect Sensor from computer
- deinstall libusb-win32 driver if it was used before (see http://ipisoft.com/forum/viewtopic.php?f=11&t=4932 for details)
- Note that if you do not plan to use Sony PlayStation Eye cameras then you can deselect the appropriate item in the list.
- “Can Windows connect to Windows Update to search for software?”
- “What do you want the wizard to do?”
- Note that values of Tilt and Roll are updated with a time lag. During recording these values cannot be updated assuming that in this case sensor should be static.
iPi Studio
- Note that if you don’t receive activation e-mail after registration then:
- Make sure that this e-mail is not in “Spam” folder of your mail client.
- Check that you have entered correct e-mail address.
- Try to resend activation email. To do it, go to login page and click “Resend activation e-mail” link.
- If none of above actions help, please report the problem to ipi@ipisoft.com.
- Important! Initial two seconds of video should contain only background and static objects. Presence of actor or any moving objects in the initial two seconds of recorded video is unacceptable. It’s because initial seconds of video are used to calculate static background necessary to separate actor from other objects of 3D scene.
- Note that current version uses only depth information to track motions. So there are no restrictions on clothes colors (just avoid shiny fabrics). Please use slim clothes to reduce noise in resulted animation.
- Run iPi Studio
- Press Ctrl+O or push “Open” button on toolbar
- Choose recorded avi file
- In the “Select Video Layout” dialog select the following values:
- Depth video from MS Kinect Camera
- Numbers of cameras: 1
- Resolution: 640x480
- Right mouse button up
- Save created project by pressing Ctrl+S or pushing button “Save” on toolbar
- Switch to “Tracking” tab and push “Refit pose” button.
- As a result model should be matched with actor image from video. If it does not happen then delete result using item “Edit” -> “Delete pose” from main menu and repeat above actions.
- Using the slider right to the button “Show Skin” in toolbar, make sure that morph of model corresponds to the actor image. If no, than adjust arms/torso/legs morph using appropriate sliders from “Actor” tab.
- Switch to “Tracking” tab, check “Enable foot tracking” and “Enable shoulders tracking” checkboxes
- To start tracking just push “Track Forward” button
- Wait and watch...
Next Steps
Video Materials
Demo video
Video Tutotial from dueyftw
"First capture using Kinect" from GMM
- Note that GMM forgot to turn on the foot tracking ("Tracking" tab), as a result foot sliding is present.
"First results" from Radiac
See also:
Frequently Asked Questions
Q: Is tracking realtime?
A: No.
A: COLLADA, BVH, SMD. Also iPi DMC can export BVH optimized for 3d Max Biped, Poser, MotionBuilder and iClone. For more info see Animation export and motion transfer
Q: And what about FBX?
A: We use driver from PrimeSense (psdrv3.sys) and OpenNI library to communicate with device via USB. Protocol implementation is our own.
Q: What does "iPi DMC" means?
Q: Is there version for Mac?
Q: How can I buy?
A: You can buy online.
