Recording a video from a depth sensor
Revision as of 15:04, 14 December 2011 by Pavel (Talk)
Environment
Side view
Top view
Actor Clothing
Recording Process
Please run iPi Recorder and choose “MS Kinect Sensor (OpenNI)” in Camera Selector dialog:
Recording Actor's Performance
Performance Tips
  • Enter the actor.
  • Strike a T-pose.
  • Action
T-pose
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
