Recording actor's performance
Revision as of 23:53, 8 December 2011 by Mini (Talk)
  • No actor at the start of the video
  • Enter the actor.
  • Strike a T-pose.
  • Action
Click to enlargeClick to enlargeClick to enlarge
“No actor at the start of the video” rule
Remember to always record a few seconds without actor in view of cameras in the beginning of each video. This is very important. The software will need to see a couple of seconds of background of your scene (no actor) when processing the video.
T-pose
It is preferable to have actor strike a “T-pose” before the actual action. The software will need T-pose for building actor appearance model during tracking.
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Ian Chisholm is an acclaimed machinima director and actor and the creator of Clear Skies machinima series. Below are some hints from his experience with motion capture for Clear Skies III.
  1. Stand a bit like a gorilla – have your arms out from your sides: Gorilla.jpg Well, obviously not quite that much. But anyway, if you don’t, you’ll find the arms clip slightly into the models and they look daft.
Takes
Naming conventions
