Recording actor's performance
Revision as of 14:57, 13 December 2011 by Pavel (Talk)
  • No actor at the start of the video
  • Enter the actor.
  • Strike a T-pose.
  • Action
Click to enlargeClick to enlargeClick to enlarge
“No actor at the start of the video” rule
Remember to always record a few seconds without actor in view of cameras in the beginning of each video. This is very important. The software will need to see a couple of seconds of background of your scene (no actor) when processing the video.
T-pose
It is preferable to have actor strike a “T-pose” before the actual action. The software will need T-pose for building actor appearance model during tracking.
Takes
Iterations
  • Record the videos
  • Give feedback to the actor
Takes
Naming conventions
