Revision as of 18:18, 9 December 2011 by Pavel (Talk)
    • Storage system: HDD or SSD or RAID with write speed at least 55 Mb/sec
  • Two Microsoft Kinect Sensors with separate power adapters
Software Installation
  1. Select needed components
Important!
Components
    iPi Recorder itself.
Good
Bad
Run iPi Recorder and make sure that there are two items “MS Kinect Sensor (OpenNI)” in “Camera Selector” dialog:
Select both items “MS Kinect Sensor (OpenNI)” and press “Ok” button. As a result you should see something like this:
Recording video from two Depth Sensors
Environment
Side view
Top view
Actor Clothing
Recording Process
Good
Bad
Calibration
The first configuration
Top view
Side view
Preparations
Good
Bad
good size
good depth data
too small
too close to human body
Recording Calibration Video
Good
Bad
Processing Calibration Video
  • Adjust the end of ROI:
  • Evaluate the result:
  • Save the result:
    • go to the Scene tab
Video tutorial from TrueBones
The second configuration
Top view
Side view
Preparations
Good
Bad
Tracking
Recording and processing of performance video is generally the same as for single Kinect solution: Quick Start Guide with MS Kinect Sensor#Processing Video from Depth Sensor.
  • switch to the Scene tab
  • etc.
Next Steps
Materials
Video
Users' Feedback
Brilliant work guys.
than with a single Kinect.
I am utterly astonished.
