User Guide for Dual Depth Sensor Configuration (printable version)
Revision as of 16:48, 14 December 2011 by Pavel (Talk)
Quick Start Guide
  1. REDIRECT Quick Start Guide for Dual Depth Sensor Configuration
User Guide
  1. REDIRECT User Guide for Dual Depth Sensor Configuration
USB controllers
  • Low cost (under $40).
Cables
Tripods
Video Card
iPi Mocap Studio relies on GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Intel integrated graphics is not supported
Please be aware that desktop GPUs are dramatically faster than laptop GPUs (due to apparent thermal constraints in laptop PCs). Laptops with switchable graphics should be configured to run iPi Mocap Studio on a discrete (high-performance) GPU.
USB controllers
USB hubs
Known compatibility issues
