User Guide for Multiple PlayStation Eye Cameras Configuration
Revision as of 17:04, 12 December 2011 by Pavel (Talk)
    • Storage system: HDD or SSD or RAID with write speed:
      • For 4 cameras at 60 fps, 640 x 480 resolution: not less than 70,4 MByte/sec
      • For 6 cameras at 60 fps, 640 x 480 resolution: not less than 105,6 MByte/sec
Note If your write speed is lower, you can work with 320 x 240 resolution and/or lower frame rate. Alternatively, you can use compressed mode (that gives 3-5 times lower required write speed, but the CPU performance may become a bottleneck)
Software Installation
  1. Select needed components
Important!
Components
    iPi Recorder itself.
iPi Studio
