User Guide for Multiple PlayStation Eye Cameras Configuration
- Storage system: HDD or SSD or RAID with write speed:
- For 4 cameras at 60 fps, 640 x 480 resolution: not less than 70,4 MByte/sec
- For 6 cameras at 60 fps, 640 x 480 resolution: not less than 105,6 MByte/sec
- Note If your write speed is lower, you can work with 320 x 240 resolution and/or lower frame rate. Alternatively, you can use compressed mode (that gives 3-5 times lower required write speed, but the CPU performance may become a bottleneck)
- 3 to 6 Sony PlayStation Eye for PS3 cameras.
- for more info see Cameras and accessories#Cameras
- 4 to 9 active USB 2.0 extension cables (depending on number of cameras and scene set-up)
- Optional: tripods to place cameras
- for more info see Cameras and accessories#Tripods
- Mini Maglite (or other flashlight) for calibration
- for more infor see Cameras and accessories#Mini Maglite (or other flashlight) for calibration
- Minimum required space: 4m by 4m (13 by 13 feet)
Important! You can plug not more than 2 cameras to one USB controller, otherwise you will not be able to capture at 60 fps with 640 x 480 resolution. for more info see USB controllers
iPi Studio
Software Installation
- Select needed components
- Important!
Components
iPi Recorder itself.
iPi Studio
