User Guide for Multiple PlayStation Eye Cameras Configuration
Revision as of 12:31, 13 December 2011 by Pavel (Talk)
    • Storage system: HDD or SSD or RAID with write speed:
      • For 4 cameras at 60 fps, 640 x 480 resolution: not less than 70,4 MByte/sec
      • For 6 cameras at 60 fps, 640 x 480 resolution: not less than 105,6 MByte/sec
Note If your write speed is lower, you can work with 320 x 240 resolution and/or lower frame rate. Alternatively, you can use compressed mode (that gives 3-5 times lower required write speed, but the CPU performance may become a bottleneck)
iPi Studio
Software Installation
  1. Select needed components
Important!
Components
    iPi Recorder itself.
Important! You can plug not more than 2 cameras to one USB controller, otherwise you will not be able to capture at 60 fps with 640 x 480 resolution. For more info see USB controllers
iPi Studio
Recording Video with Multiple PlayStation Eye Cameras
Environment
Space
For a multi-camera configuration, you need a minimum of 13 feet by 13 feet space (4 meters by 4 meters). At smaller space, actor simply won’t fit into view of cameras.
Background
Lighting
Actor Clothing
Special considerations
Don’t stand too close to a wall. Shadows on the wall may confuse the system. If standing close to a wall is unavoidable you should use additional light sources to light the wall behind actor to minimize shadows.
