User Guide for Multiple PlayStation Eye Cameras Configuration
Revision as of 14:48, 13 December 2011 by Pavel (Talk)
    • Storage system: HDD or SSD or RAID with write speed:
      • For 4 cameras at 60 fps, 640 x 480 resolution: not less than 70,4 MByte/sec
      • For 6 cameras at 60 fps, 640 x 480 resolution: not less than 105,6 MByte/sec
Note If your write speed is lower, you can work with 320 x 240 resolution and/or lower frame rate. Alternatively, you can use compressed mode (that gives 3-5 times lower required write speed, but the CPU performance may become a bottleneck)
iPi Studio
Software Installation
  1. Select needed components
Important!
Components
    iPi Recorder itself.
Important! You can plug not more than 2 cameras to one USB controller, otherwise you will not be able to capture at 60 fps with 640 x 480 resolution. For more info see USB controllers
iPi Studio
Recording Video with Multiple PlayStation Eye Cameras
Environment
Space
For a multiple PlayStation Eye configuration, you need a minimum of 13 feet by 13 feet space (4 meters by 4 meters). At smaller space, actor simply won’t fit into view of cameras.
Background
Lighting
Actor Clothing
Special considerations
Don’t stand too close to a wall. Shadows on the wall may confuse the system. If standing close to a wall is unavoidable you should use additional light sources to light the wall behind actor to minimize shadows.
Recording Process
iPi Recorder Setup
Framerate
4 cameras at 320 by 240 resolution
4 cameras at 640 by 480 resolution at 60 frames per second
6 cameras at 640 by 480 resolution at 60 frames per second
USB controllers
Scene Set-up
Three Camera Configuration
Recommended configuration for 3-camera setup is a half-circle:
Example:
Virtual view of the same scene:
Four Camera Configuration
You can set up 4 cameras in a half-circle or a full-circle configuration, depending on available space. You can improve accuracy by placing one of the cameras high over the ground (like 3 meters high).
Recommended configuration for 4-camera setup in half circle:
Example:
Six Camera Configuration
You can set up 6 cameras in a full-circle or a half-circle configuration, depending on available space. You can improve accuracy by placing one or two cameras high over the ground (like 3 meters high).
Recommended configuration for 6-camera full-circle setup:
Camera Setup
Install the cameras on tripods and connect cables.
Sony PlayStation Eye cameras do not have standard tripod mounting screw, so you will have to use some kind of ad hoc solution. The simplest approach is to fix the cameras to tripods using sticky tape.
When mixing active and passive USB cables, make sure cable connection order is correct (computer->active cable->passive cable->camera).
If you're using the PlayStation Eye camera, make sure you have the lens set to the wide setting.
Calibration
{{:Calibration
