Revision as of 14:04, 29 November 2011 by Pavel (Talk)
Software Installation
iPi Studio
Environment
Side view
Top view
Actor Clothing
Recording Process
  • Run iPi Studio
  • Choose recorded avi file
    • Numbers of cameras: 1
    • Resolution: 640x480
    3. Right mouse button up
  • Wait and watch...
Next Steps
Video Materials
Demo video
"Car scene" by JeanDellac
Animation by NextGenReport
"First results" from Radiac
See also:
Frequently Asked Questions
Q: Is tracking realtime?
A: No, not yet.
Q: What about head tracking?
Q: Is FBX format supported?
A: Yes.
Q: What does "iPi DMC" means?
  • iPiRecorder - a tool for recording video from web cameras and depth sensors;
  • iPiStudio - software application for processing pre-recorded video and exporting resulting animation.
A: You can buy online.
