Video recording
Revision as of 21:44, 30 October 2010 by Mini (Talk)
iPiRecorder
For multi-camera video, you should use webcams (or other USB or Firewire cameras) and record a multi-camera video using iPiRecorder. Current release of iPi Desktop Motion Capture does not have other multi-camera options.
iPiRecorder works with Sony PlayStation Eye cameras and DirectShow-compatible webcams (USB and FireWire).
iPiRecorder is a stand-alone application and does not require a powerful video card. You may choose to install iPiRecorder on a notebook PC for portability. Since iPiRecorder is free, you can install it on as many computers as you need.
Framerate
4 cameras at 320 by 240 resolution
4 cameras at 640 by 480 resolution at 60 frames per second
6 cameras at 640 by 480 resolution at 60 frames per second
A six-core CPU is recommended for recording at 640 by 480 resolution at 60 frames per second. You will also need to get additional USB controller.
Raw Bayer Mode
Sony PlayStation Eye camera supports special operation mode called “raw Bayer mode”. The name “raw Bayer mode” comes from the Bayer color filter array used in PlayStation Eye camera (filter array being named after Eastman Kodak researcher Bryce E. Bayer).
Raw Bayer mode is very efficient in terms of USB bandwidth usage and therefore is highly recommended.
Videos captured in raw Bayer mode look like multiple monochrome image planes. This is normal. You should not have any problems opening raw Bayer mode videos in iPiStudio.
USB controllers
