Cameras and accessories
Revision as of 21:06, 22 September 2010 by Mini (Talk)
Recommended camera for use with iPi Desktop Motion Capture is PlayStation 3 Eye. http://us.playstation.com/ps3/accessories/scph-98047.html The following properties make it a preferred camera for motion capture: • High frame rate - up to 60 frames per second (important for reducing motion blur and capturing fast motions like dancing, boxing or running). • Fully automatic configuration with excellent auto-exposure and auto-gain. • Very good low-light sensitivity. • Low-distortion wide-angle fixed optics. • Efficient protocol for image transfer (saves more than 50% of USB bandwidth when compared to other webcams). • Low cost (under $40). The only downside of PlayStation 3 Eye is its lack of tripod mount screw. A possible solution is to use sticky tape to fix it to tripods.
Cables
You will need USB 2.0 extension cables. For distances over 5m, you should use active USB 2.0 extension cables: http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=active+USB+2.0+extension+cable&x=14&y=22 You can daisy-chain multiple active USB 2.0 extension cables for distances longer than 10m. When combining active and passive cables, make sure that the connection order is correct (computer->active cable->passive cable->camera).
Tripods
Inexpensive tripods like http://www.amazon.com/Zeikos-ZE-TR26A-50-Inch-Full-Tripod/dp/B001T9N0L2/ref=sr_1_18?s=photo&ie=UTF8&qid=1285026270&sr=1-18 should be fine for use with iPi Desktop Motion Capture. Mini Maglite (or other flashlight) for calibration You will need a small bright object for calibration. It is recommended to get Mini Maglite (or other similar flashlight) for that purpose: http://www.maglite.com/product.asp?psc=2AACELL
Optional: a video card
iPi Desktop Motion Capture relies on video card’s GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Please be aware that desktop GPUs are dramatically faster than notebook GPUs (due to apparent thermal constraints in notebook PCs). To give you an idea of potential performance for various GPU models below are some benchmark results:
