Cameras and accessories
Revision as of 14:53, 24 September 2010 by Mini (Talk)
Recommended camera for use with iPi Desktop Motion Capture is Sony PlayStation 3 Eye.
  • Low cost (under $40).
Cables
You will need USB 2.0 extension cables. For distances over 5m, you should use active USB 2.0 extension cables: http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=active+USB+2.0+extension+cable&x=14&y=22 You can daisy-chain multiple active USB 2.0 extension cables for distances longer than 10m. When combining active and passive cables, make sure that the connection order is correct (computer->active cable->passive cable->camera).
Tripods
Inexpensive tripods like http://www.amazon.com/Zeikos-ZE-TR26A-50-Inch-Full-Tripod/dp/B001T9N0L2/ref=sr_1_18?s=photo&ie=UTF8&qid=1285026270&sr=1-18 should be fine for use with iPi Desktop Motion Capture. It is recommended to place at least one of the cameras reasonably high (2 or 3 meters high) so you may need a high tripod like [1] or some kind of ad hoc wall mounting solution.
You will need a small bright object for calibration. It is recommended to get Mini Maglite (or other similar flashlight) for that purpose: http://www.maglite.com/product.asp?psc=2AACELL
Optional: a video card
iPi Desktop Motion Capture relies on video card’s GPU for calculations. Therefore, it is recommended to use a fast GPU for processing recorded videos. As a minimum, you need a Shader Model 4.0-compatible (DirectX 10-compatible) GPU. Please be aware that desktop GPUs are dramatically faster than notebook GPUs (due to apparent thermal constraints in notebook PCs). To give you an idea of potential performance for various GPU models below are some benchmark results:
Tracking speed for various video card models
