Depth Sensors Comparison
Revision as of 17:28, 11 March 2012 by Pavel (Talk | contribs)
MS Kinect for Xbox or Windows
ASUS Xtion
ASUS Xtion Live
Kinect vs Xtion
Both Microsoft Kinect and ASUS Xtion sensors are based on the same PrimeSense infra-red technology. So all basic characteristics critical for full-body motion capture are generally the same. But there are certain diffeneces that you can take into account:
Device Pros Cons
Kinect
  • Require ACDC power supply
  • Only 30 fps frame rate
Xtion
  • Allow 60 fps frame rate (at 320 x 240 resolution only)
  • Less popular device
  • Lower drivers quality
  • Does not work with some USB controllers
Xtion Live vs Xtion
  • ASUS Xtion Live is recommendable because it includes RGB sensor. RGB image is currently not used for tracking, but it helps to operate the system
Kinect for Xbox vs Kinect for Windows
