IPi Recorder Installation
Download the setup package of iPi Recorder latest version: [1]. Run it. In the following dialog window make sure that
- item Playstation3 Eye Webcam :: WinUSB Drivers Registration is selected or marked as ALREADY INSTALLED if you plan to work with Sony PS Eye cameras
- both items ASUS Xtion :: OpenNI Redistributable and ASUS Xtion :: PrimeSense Sensor are selected or marked as ALREADY INSTALLED if you plan to work with ASUS Xtion or ASUS Xtion Live depth sensors
- item Microsoft Kinect :: MS Kinect SDK 1.5 is selected or marked as ALREADY INSTALLED if you plan to work with Microsoft Kinect for Windows or Microsoft Kinect for XBOX 360 depth sensors
- Note 1. MS Kinect SDK is not supported on Windows versions prior to Windows 7. When running installer on those versions, select item Microsoft Kinect :: PrimeSense psdrv3.sys Driver Registration to work with Kinect sensors.
- Note 2. iPi Recorder does support working with Kinect sensors on Windows 7 using psdrv3.sys. If you have installed and used it for Kinect with iPi Recorder 1.x, you can continue to using it with iPi Recorder 2.
